Cams for A15
Quite a regular
From Victoria
Hey guys, just purchased myself a Datsun 1200 Ute with an A15 with extractors. Was wondering what cams would be good to add some power and a lumpy'ish idle. Cheers, Cody
Posted on: 2013/7/27 13:51
Re: Cams for A15
Use the same cams as A14, as the bore size and RPM rev-ability is the same. The later A15 comes with a mild cam, earliest A15 comes with the high-RPM cam (same as A14). This stock early is good for 5000 to 6000 RPM power and has a smooth idle.
For higher power (higher revs) use a higher duration cam which will also give a lumpy idle. It will result in less power below 5000 RPM, but more power above 6000 RPM -- if you have a larger than stock carburetor.
For example, Auckland Cams #566 239/239 Lopey idle 4000-7000 RPM. See Camshafts.
Posted on: 2013/7/28 2:48
Re: Cams for A15
Quite a regular
From Victoria
Thanks. Will I need to raise compression ration and valve springs though?
Posted on: 2013/7/28 8:31
1982 Datsun 1200 Ute- Getting resprayed and partly shaved
A15 Engine
5 Speed
Re: Cams for A15
Tomei are now also making "street" cams for A-series.
Their cams are expensive but it would be worth it.
Posted on: 2013/7/28 9:33
