Where can I get pistons fly cut ?
I need some advice, I have my a14 bottom end together and I need to get the pistons fly cut and check all the clearances to work out the compression ratio. Is there any good places around Sydney who can do this for me ?
Posted on: 2013/8/5 7:43
Re: Where can I get pistons fly cut ?
From windsor, sydney
If you can get on a Bridgeport mill at your work you can cut them yourself
Posted on: 2013/8/7 11:49
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
I have fly cut a piston using a old head and grinding the valve and welded to make a cutter and using a drill cut valve clearance
Posted on: 2013/8/7 14:22
From sydney.nsw
i can help you call me.cheers
Posted on: 2013/8/7 15:07
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
