B310 round headlight bumper
From Adelaide, SA
Morning,
I have a B310 and doing a bit of research in the Wiki I found there are other options for the fron bumper. Mine has the black end caps, looking to replace it anyway as it is damaged but curious to see if anyone else has swapped for one of the nicer looking all metal ones such as this or this?
Mine is just the stock one with black end caps (see pic).
How about the rear? Same options available there?
Thanks guys!
jpg  datto.jpg (118.64 KB)
2602_520ea0f73dbe9.jpg 816X612 px
Posted on: 2013/8/16 22:59
Re: B310 round headlight bumper
In Japan they are usually swapped for the all-metal versions. Don't know anyone here or in AUS that has swapped.
Posted on: 2013/8/17 5:40
From Adelaide, SA
Righto, thanks mate. Seems like it might be near impossible to find one so I think i'll just try and find a new stock bumper as a replacement.
Cheers!
Posted on: 2013/8/19 19:17
They are for sale on Yahoo Auctions. Bumper B310 Sunny search
Also some Aussie cars have them. They are simply the lowest trim level. The more expensive ones have the black rubber ends.
Posted on: 2013/8/19 20:57
From Adelaide, SA
Yeah righto, thanks for the info. Will check out the Yahoo Auctions site
Posted on: 2013/8/20 0:59
Those bumpers are in demand over here too. Local wagons were fitted with the all metal bumper. Wagon rear bumper touches sedan bodywork a bit at the corners, need a little tweak to fit but it doesn't have a reg. plate slot for the round headlight B310 sedan. OK for square headlight B310 sedan.
You need the brackets as well as the bumper fits closer to the body. There's no filler between bumper and body like you have now.
Posted on: 2013/8/25 4:11
I don't know about other countries but our round lamp B310 actually has the all metal bumpers but fitted with end caps and different brackets to accommodate fillers.
Posted on: 2013/8/25 4:51
