Clutch kit or source for parts for t50 clutch change?
From Sydney, NSW
Hi my thrust race is starting to get noisy so I figured it's time to do the clutch at the same time.
I was just wondering if anyone knew who sells a clutch kit to suit the conversion as I have an a12 with a t50 behind it originally from dellow I believe
I know the clutch plate is toyota, the thrust race is a modified datsun if i remember correctly? and the pressure plate is datsun?
Just wondering if anyone knew where to get a suitable kit or could point me in the right direction?
Also does anyone have any recommendations as to a suggestion to machine the flywheel to make sure it all marries up nicely around sydney?
Cheers,
Tom
Posted on: 2013/9/2 12:10
Re: Clutch kit or source for parts for t50 clutch change?
From Sydney
Hi, I don't think you can get an off the shelf clutch plate for that setup unless you go to dellow. Try the guys at western clutches at st Mary's, they are clutch specialists and know their stuff.
Posted on: 2013/9/2 13:16
From Melbourne, Australia
From memory its the celica thrust bearing and all Datsun clutch. But the clutch plate you get from dellow as they supply the Datsun plate with the spline changed to suit celica input shaft. A quick call to fellow to confirm is definitely best
Posted on: 2013/9/2 13:58
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Brisbane, Narangba
It's a Datsun thrust bearing on a machined celica carrier. Then datsun clutch/pressure plate with celica splines. Best thing I ever did what just have the datsun flywheel drilled to suit the 200mm celica pressure plate. Now its just all off the shelf toyota with much better clamping force than the other setup.
Posted on: 2013/9/2 23:35
From Sydney, NSW
thanks for the replies! Freak do you change the carrier each time?
was it hard to find someone to machine the flywheel/expensive?
Posted on: 2013/9/2 23:55
Why not use a standard off-the-shelf 180mm clutch disk for the toyoda T50 transmission? It is 21-spline.
Edit: Exedy TYD023U is 180mm, 21-teeth spline, Spline OD 24.1
Starlet 1985-1994 some models, e.g. E2 engine.
Posted on: 2013/9/3 1:43
Edited by ddgonzal on 2013/9/3 2:00:50
Edited by ddgonzal on 2013/9/3 4:37:49
From Sydney, NSW
Cheers DD,
not sure I was just trying to work out what I need to order as this is the first clutch I've done.
Cheers,
Tom
Posted on: 2013/9/3 1:51
From Perth
I also use a 200mm Toyota clutch on a flywheel drilled to suit
But use the Datto bearing on the original (modified) carrier
It just presses off/on
Posted on: 2013/9/3 10:45
From Sydney, NSW
cheers dattoman.. can you re-use the carrier with a new bearing?
Can anyone recommend someone in sydney to do the flywheel modification? got any part numbers for the 200mm clutch? and the rest of the kit?
Cheers,
Tom
Posted on: 2013/9/3 11:26
From Sydney, NSW
dd does that mean you could use the pressure plate off the same model?
How did you find that info doing some Googling yielded nothing
Posted on: 2013/9/3 23:02
