heater control and motor
From Colac, Victoria
my 1980 1200 ute's interior has been pulled apart and put back together, the hot to cold control works but no fan or switch to turn on fan. how do you turn on the fan (i.e. where is switch on dash)
Posted on: 2004/5/12 11:46
Re: heater control and motor
From Canberra, Australia
The bottom heater control, has a picture of a fan on it. Pull the switch out... it has two levels...
Posted on: 2004/5/12 16:11
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
But the problem is there is no knob on my dash where should it be. i suspect the switch has been replaced by the choke cable. when the cable knob is removed the whole in the dash looks likke an upside down T is the location. is it a push or twist knob. a pic would be great by any chance
Posted on: 2004/5/13 8:44
The bottom lever has the fan symbol on it. Pull it out to turn on the heater fan motor.
Posted on: 2004/5/13 8:54
