Browsing this Thread:   3 Anonymous Users
« 1 ... 6 7 8 (9) 10 »
Re: (no longer) a pretty lame intro :(
From vancouver, wa. usa
Thanks. Like wich ever you want. I like em all, but my 1200 is the beez elbows, because they dont have knees.
Posted on: 2013/9/11 19:45
72, 1200 coupe
77, 710 2 door sedan
I like the yellow coupe too. Bigger, roomier, handles better, rides smoother and gets better fuel economy. The B310 is perhaps the best Datsun ever.
Posted on: 2013/9/11 19:53
It is pretty awsome. Not argueing that.
Posted on: 2013/9/11 19:57
72, 1200 coupe
Just realized my 510 hasnt made an appearance here...
So skip to the bottom for pics, cause the mod list is.. long.
This is my 71 4 door sedan with a 68 tail pan and lights
It is gutted and caged
L16 running l18 crank and rods. .40 over l18 flat top pistons.
Closed chamber w53, with z valves.
Balanced
Isky (old... softer core :() .510, 290 cam
Nismo springs and retainers. Super light polished rockers
Cannon mani and 45 single, runnung custom chokes (42mm)
Nismo aluminum flywheel.
Zx 5 speed, aluminum drive shaft
Nismo r180 lsd rear diff
Slotted rear crossmember, with huge exaust tunnel
Willwood peddles
Willwood in cabin master cylinders
Willwood s.s. braided brakelines
Willwood 4 pot front calipers and big vented disks
Willwood 2 pot rear calipers and big solid disks
2 way adjustable coilover front struts, 4 way adjustable camber caster plates, 6 way adjustable inserts
Rear coilovers (one way adjustable) and 6 setting inserts
Nismo t.c. rod cup style bushings
Willwood brake bias controller
Crane fireball coil, crane ignition box
Fire suppression system, catch cans, blah blah blah.... lots of other stuff. Huge holly fuel system, 1/2" ss braided fueal lines blah blah blah.
Heres some pics.
Note the jack points in the rockers. I have rubber plugs made to fit in them. But the car is so low I have to use the rocker jack points all the time.
Posted on: 2013/9/14 3:22
Edited by RedBanner on 2013/9/14 4:54:24
72, 1200 coupe
nicely done
Posted on: 2013/9/14 4:43
Thank you.
Posted on: 2013/9/14 20:06
72, 1200 coupe
Real life hotwheels car. Soooo low too
Posted on: 2013/9/15 5:04
Indeed it is. Even lower than it looks.... hence the jack points.
Got.some 15s so I may be lifting it some.
Posted on: 2013/9/16 5:57
72, 1200 coupe
Ive had alot of trouble getting the correct centerlink for my 120p for awhile. Kept getting shipped different things that wernt even close.
This last time I tried rock auto... they sent me a 210 centerlink twice, and the second time they just said to keep it.... so I might as well try and uses it.
Well anyone who has tried swapping a centerlink will know, the idler is different, along with every ball joint being smaller than other datsuns.
So I miss matched some parts and here is what I eventuly used.
Idler is from a 710, centerlink is from a 210, and the inner tierods are from a 510.
Outer tierods are 1200, as are the new balljoints.
The mod I had to do, some folks might not agree with, but I had to ream out the steering arm. Yah yah I wouldnt usualy do it, but I was in a bind, I might swap steering boxs in the future. But for now its working awsome. Heres some pics.
Posted on: 2014/1/11 1:50
72, 1200 coupe
Wow, how's it handle now?
Posted on: 2014/1/11 5:05
