WTB Stronger Bolt In Diff for my 1200 4dr Sedan
Quite a regular
From Gold Coast
hi guys,
Just wanting to see whats out there before i go turbocharging my a12 :) anyone have stronger than a h145 for sale? on the gold coast/brisbane?
fonz
Posted on: 2013/9/16 3:37
Re: WTB Stronger Bolt In Diff for my 1200 4dr Sedan
From Gold Coast, Australia
If you have no luck try Chris from DatsunMuseum.com
He has a giant pile of Datsun Diffs and he is in the Brisbane area.
Ash.
Posted on: 2013/9/16 8:21
www.datsun1000.com
1967 Datsun B10
Hi yes i do have a few options here :)
Posted on: 2013/9/16 12:22
You can swap the center section from a 1975-up 120Y or B310. No special tools are needed. And it is stronger. Use the matching driveshaft.
Nothing is pure bolt in, though the 1975-1978 B210 rear axle assemblies come closest (sedan swaps to sedan, coupe to coupe). Everything else requires some bracket fabrication welding.
Posted on: 2013/9/16 19:40
Quite a regular
From Gold Coast
thanks guys,
ddgonzal, so your saying i can use a 120y centre? arent they a h150? as apposed to my h145? so if i just remove my centre and throw in a 120y centre and use the 120y tail shaft?
little confused on that one :P
fonz
Posted on: 2013/9/16 21:34
You can use a 120y borg warner 68 diff. Stronger than the h165 diffs. Bolts into sedan but you need the 120y u bolts and the plates to the leaves.
Only comes on post 1974 aus assembled 120y 4 door sedans.
Get the tail shaft too but may need shortening. Bonus is they have rebuildable unis
Posted on: 2013/9/16 22:56
Correct. A 120Y sedan rear axle assembly will bolt into a 1200 sedan, if you use enough of the parts (driveshaft, u-bolts, etc). It can be the BW68 or H150 types.
The driveshafts are all rebuildable using simple hand tools, except if you try to use the Nissan parts.
Posted on: 2013/9/16 23:01
