« 1 (2) 3 »
Re: aidaniels supercharged 1200 ute *take 2*
From northern 'burbs adelaide
should work well
Posted on: 2011/2/6 2:36
From cold toast
unreal ^^^^^
Posted on: 2011/2/8 7:37
haha well as always its been a long time between efforts put into the ute but have a new plan and new found motivation ... im going SR 4 link rear end custom front end and full cage. plan is to do hill climbs, bit of circuit and maybe some drag passes
Posted on: 2013/10/2 2:37
out with the old rusty crap
new chassis
R31 diff im gonna cut down to fit
Posted on: 2013/10/2 2:42
Re: aidaniels (no longer) supercharged 1200 ute
From Adelaide
Megasquirt works with EDIS and has instructions on how to make them talk. Although, MSII will run two coils for wasted spark directly. You could probably reflash a second hand delco unit as well. Have a look at http://pcmhacking.net/forums/. I may consider that route next time.
Posted on: 2013/10/2 10:21
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Why shorten it? Would be heaps better to widen track all around
Posted on: 2013/10/2 10:30
it needs like 200mm off both sides haha
Posted on: 2013/10/2 14:45
Is this your new found motivation after rubbing knobs with Stu?
Posted on: 2013/10/3 14:22
yea stu gives the best gobbies haha
Posted on: 2013/10/3 14:32
got a little more done to the back ... ive got some ideas for the front setup but we will see how that pans out
Posted on: 2013/10/15 13:17
« 1 (2) 3 »
