a15 pistons
From QLD
hello all,
sorry in new to this.
im starting to build a 1500 I read that most guys put je pistons in them but don't tell what type they are. im chasing where I can buy new je forged pistons that are 77mm. because the je web site doesn't help at all.
thanks
Posted on: 2013/10/9 8:19
Re: a15 pistons
for JE you order custom pistons. Tell them what size you want. But why bother with 77mm? Go with 79mm for maximum horsepower.
Posted on: 2013/10/9 17:26
Re: a15 pistons
From sydney australia
I reckon going to 77 mm first up for a road engine means you get 2 more goes at an engine rebuild (78mm next, 79mm , maybe 80mm). If it's a race engine, you go for biggest overbore, & the engine block is considered replaceable. If it's a road car & you want to keep the same engine number, the smallest you can get away with is a good idea.
Posted on: 2013/10/10 9:39
