stanza calipers disks and pads
Selling my stanza stock brakes. These came on my stanza and worked fine.
Had my old sumitomos so put them on my stanza.
Located in Melbourne but the come in this beautiful brown box that can be posted at your expense Australia wide.
The disks are ok just have some surface rust you could wet dry lightly off.
$50
Posted on: 2013/11/6 8:28
Re: stanza calipers disks and pads
From sydney australia
I'll take them. PM me a bank account number & I'll put the money in it. The postcode here is 2145. This should help with calculating the postage. Got some 200B struts that these'll fit. or call on 02-9631-2043.
Paul
B310GX
Posted on: 2013/11/6 8:51
They dont have hubs. So if you have them your all good. Will pm latwr tonight after work out postage. Cool.
Posted on: 2013/11/6 8:57
The 200B struts came with hubs but no discs or calipers, so these are perfect. I finish early fridays, so I can do a direct deposit to your account. The only other choice is whether I get a coil over kit, or just replace the large spring perch with a smaller one. Probably the second one.
Posted on: 2013/11/6 18:56
Use the smaller perches if you have some otherwise coilover is just as easy.
Get some 240z gas shocks in there and let the good times roll.
I had cheap Gabriels in mine and were matched to 190lb springs quite well.
Better shocks would be suited to 225 springs if you are tracking it from my experience.
Im still using 240z shocks on my stanza and they are ok with 275lb springs. Ideally id prefer 300lb
Posted on: 2013/11/6 21:10
