Info on how to setup fuel injection
Hey guys , I am currently trying to find info on what people have used or modified to setup injection on a a series , I am a machinist by trade so i will be using a weber manifold modified for injectors and making a plenum but I'm after info on what computer , dizzy throttle body and what size injectors etc any info or pics would be great
Posted on: 2013/11/16 6:12
Re: Info on how to setup fuel injection
From Kelmscott Western Australia
Electric dizzy e15 single coil or if you want use a e15 turbo that gives you the advantage to use 4 coils computer of your choise (aftermarket) im using a A series factory manifold
Posted on: 2013/11/16 8:13
71 Datsun 1200 ute with A14 fuel injection and T50
59 Morris minor ute with A15 fuel injected with intercooled turbo
Also need sensors fuel return line
Posted on: 2013/11/16 8:18
From Adelaide
If you're after some reading to get an understanding of how all the pieces fit together here's a good resource http://www.megamanual.com/index.html. The people on this forum will be able to help with specifics. The website above has guides on throttle body sizes, injector sizes etc. An even easier way is to just grab stuff off similar sized engines.
There's so many different ways to do it that will work. I'm using:
CBR1000rr injection throttle bodies with stock injectors on a custom manifold
Megasquirt II
EDIS ignition (ford trigger wheel setup)
Custom surge tank with a fuel pump fitted inside it.
It's not running yet but slowly getting there. There's heaps of info in the TechWiki as well.
Posted on: 2013/11/17 0:46
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
See our club tech article EFI.
If you are a do-it-yourself person, i'd suggest MegaSquirt as the most flexible ECU. It can use any distributor, but an EI distributor is recommended for reliability (there are several factory A-series electronic distributors to choose from or you can convert an E15/E16 or Bluebird dizzy). MegaSquirt can use Datsun injectors like the 280Z injectors that were used in the factory A14E efi engine.
Posted on: 2013/11/17 7:14
