help pleas .. 5speed or 6speer gearbox for 1/4 mile
Not too shy to talk
Good morning ...
I am building a sr20det datsun gx coupe for 1/4 miles
I can get a sr20det only with a 6 speed manual gearbox... ?
Will it work for 1/4 miles....??
Do you get a 5 speed gearbox for sr20det..??
Tanx
Posted on: 2013/11/23 8:42
Re: help pleas .. 5speed or 6speer gearbox for 1/4 mile
4 speed will be quickest, but they don't come with 4-speed boxes.
Only S15 motors came with six-speed
S13 and S14 SR20DET came with 5-speeds
Posted on: 2013/11/23 8:45
Not too shy to talk
So my best options will be the 5speed ?
Posted on: 2013/11/23 9:01
From Brisbane
Both gearboxes aren't that great for drag racing. If you want manual still? Their are adaptor kits worth looking into for rb25 or z31 boxes
Posted on: 2013/11/23 11:11
From Perth
If its only for drag racing your best gearbox is a 3 speed auto
Posted on: 2013/11/23 11:37
Not too shy to talk
Tanx for all the info
Posted on: 2013/11/23 17:46
From Snohomish, WA USA
If the 5 speed is just the overdrive from the 4 speed, then it doesn't make a difference. What does make a difference is each gears ratio, your rearend ratio, the diameter of your tire and your RPM's when you need to shift. That will determine what your speed will be at each shift. Use a gear ratio calculator to determine all of this. You can find one on the net.
After that you can manipulate the tire size and rearend gear ratio.
Posted on: 2013/11/24 5:50
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
