WANTED 180SX or silvia instrument cluster
From Melbourne,Australia
Hi huys im after the instument cluster out of a ca18det equiped 180sx or silvia dose anyone have one left over from there front cut that they want to sell?
Posted on: 2004/5/17 8:32
Re: WANTED 180SX or silvia instrument cluster
From Sydney, Australia
Why do you need one?
If you just want a cool speedo and stuff, then the SR20DET version Silvia dash will also work. I "think", it has the same signal for the speed sensor pin on the ECU, they certainly use the same "Sender unit" at the gearbox.
The Dash cluster is very well labelled and quite easy to wire up, even if you don't have the loom. But as the tracks are copper on plastic sheeting, you should try and use the cluster loom.
I'm considering looking for a reasonable 1200 dash, and a good Silvia Dash, and integrating the two dashes. Then getting it re-skinned so it looks like it is semi-factory.
Posted on: 2004/5/17 11:30
