Blow through turbo build thread ?
From Mordialloc Victoria 3195
Can anyone suggest someone's build thread here, or on another forum, that's done a blow through turbo setup on an A series using bike carbs.
Think I've got just about all the info and gear ready that I need, but would be nice to read, or chat to someone who's been there and see how they did it.
Cheers David
Posted on: 2013/12/10 6:40
keep it simple
Re: Blow through turbo build thread ?
I don't think anyone has done it yet. Blow-thru yes, blow-thru bike carbs no. But should work just like dual DCOE blow through setups. There are tons of different bike carbs, and using a hatted setup is a little more easily done than boxing the carbs (for 5-10 psi boost, which is all you'd want without an intercooler anyways).
Posted on: 2013/12/10 8:42
Heres is a suzuki 8v sohc g16a motor same valve sizes as the 8v h89 head but hemi chamber and with a mild cam made 78hp atw using 32mm bike carbs no boost.
With boost using smalle turbo made 147hp atw blow through 32mm carbs
http://www.theturboforums.com/threads ... -samurai-1-3-blow-through
its not all about big carbs the 32mm gsxr carbs seem to do well even on a 1.3
http://www.suzuki-forums.com/suzuki-j ... engine-vs-swapping-3.html
Posted on: 2013/12/11 1:27
Thankd for reply-
ddgonzal - I'll be using a set of 34mm kein CVK's which seem to be one of the easier to setup for equalising the intake manifold pressure with top of the fuel bowl through the bowl vent tubes. Cant for the life of me remember the turbo size model No. but its only small , internal wastegated - rated to 140hp, will post it later if anyones interested!
D Thanks for the thread links - going to have a look now
Cheers David
Posted on: 2013/12/12 4:24
keep it simple
