Points to CDI conversion kits
Points to CDI kits
easy install, replaces points with CDI (trouble free, better performance)
available soon....$60set
www.keicarshop.com
jpg  cdipoints.jpg (7.72 KB)
15999_52a7d54d10d0e.jpg 300X276 px
Posted on: 2013/12/11 3:01
Re: Points to CDI conversion kits
What is the advantage of CDI over regular electronic ignition?
Posted on: 2013/12/11 7:31
PRICE..... this kit fits standard point distributors
Posted on: 2013/12/11 8:47
From Mordialloc Victoria 3195
if its like a bike cdi it may have a set rev limit in it?
Posted on: 2013/12/18 11:43
keep it simple
Shame the web site says for 3cyl cars. Id like one in the ford
Posted on: 2013/12/18 12:09
From Adelaide
There's a fair bit of info on the web about it. CDI is better where you need higher voltages to get a spark. It's used in small engines and 2 strokes where fouling can be an issue and also in some high CR or high boost engines where getting a spark can be an issue.
The down side is the spark duration is shorter so it's not as good for lean burn or cruise conditions.
Edit: CDI is better for starting with low battery voltage compared to a standard Kettering system although many electronic ignitions have compensation.
Posted on: 2013/12/19 1:17
Edited by lamb_daiquiri on 2013/12/19 6:36:28
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
4 cylinder kits arriving soon
Posted on: 2013/12/23 4:39
Edited by supercharger on 2013/12/23 23:38:16
