« 1 2 (3)
Re: Starting Issue
From Sri Lanka
Hi Guys
I think What DD said is correct, i pulled the starter motor out and checked it,it is turning both side , clockwise it is soft anticlockwise it is little hard but yet it can be turned by finger tips , is my starter motor repairable ? if so what part needs to be replaced please advice me, thanks for great ideas and help
thanks
regards
sumith
Posted on: 2013/12/19 15:33
Re: Starting Issue
Yes, the drive gear is replaceable. As a test, you may swap the starters from your two Datsuns to see if it makes a difference.
Posted on: 2013/12/19 17:27
Re: Starting Issue
== Testing Overrun Clutch ==
If your starter "whizzes" just after the engine catches, the Overrun clutch is almost for sure bad. If you do not replace it, eventually it will wear so much it free spings, instead of turning the engine.
# Remove starter from engine
# With your fingers, turn the small drive gear.
#* It should smoothly turn one direction
#* It should NOT turn at all the other direction, not even a little bit
Posted on: 2013/12/19 17:34
Re: Starting Issue
From Sri Lanka
Hi DD
Thanks, i have tried to Swap it with my b210 earlier ,it did not fit Bolt Pattern is different i will replace the drive gear now i am sure i have the exact problem as you said .this small problem came so far so long that i have never thought, any way for sure i know i have almost replaced all my ignition system and it will have a long go
thanks
regards
sumith
Posted on: 2013/12/20 2:31
Re: Starting Issue
From Sri Lanka
Hi Guys
i pulled the starter motor this part out
http://www.fixkick.com/nostart_files/starter_motor_pinion.jpg
and checked it , but when it is out it is turning only one direction is there any possibility like that for it to behave differently when fixed and removed, what should be checked further more, or shall i refix it in order again and check it back again ?
thanks
regards
sumith
Posted on: 2013/12/21 4:21
Re: Starting Issue
How can the a series starter patterns be different?
Posted on: 2013/12/21 10:51
Re: Starting Issue
From Sri Lanka
Hi unfamila
they are 1974 B210 GX with A12S, and 1978 Hb310 GL with53 A12A, they are different i don'y know how ? they are hitachi but have different casting nos
b210-S114-160D 85Q
b310-s114-253 83H
Posted on: 2013/12/21 14:40
Edited by Sumith on 2013/12/21 14:58:35
Re: Starting Issue
Yes the starter castings differ slightly. But they use the same bolt pattern.
Posted on: 2013/12/26 6:16
« 1 2 (3)
