« 1 (2)
Re: Datsun 1000 with a F20C Honda engine and 6 speed box (s2000)
S2000 is heavier than a stock ca18det and turbo injected L series and latest Chrysler Hemi 2 twin spark all alloy v8.
185kg 148kg engine 37kg box
jpg  408lbs honda s2000.jpg (154.23 KB)
737_52ce1db921fac.jpg 768X1024 px
Posted on: 2014/1/9 3:58
From Brissy
way to dig up an old thread D...lol but good info anyway, i know of a 1200 sedan with a s200 motor in QLD
Posted on: 2014/1/9 5:51
S2000 ought to way more than an engine - it's a whole car.
That 408 pounds (185 kg) is for the FC20 engine and the 6-speed transmission combined.
Posted on: 2014/1/9 6:18
From WA perth
you need power steering
Posted on: 2014/1/9 13:01
Its so heavy and exxy to rebuild the Yanks do a 40kg heavier LS v8 crate engine kit with tremec for better performance and handling that hardly raises a sweat due to the torque & double the hp. Theres also a GM rear end conversion. The New Hemi 2 weighs the same as the FC20.
Better update the old threads than start a new one that way all info in one area and less work for filing
Posted on: 2014/1/9 13:24
Edited by D on 2014/1/10 1:16:32
128kg CA18DE engine
43 kg CA18DET gearbox
______
171 kg combined
http://datsun1200.com/modules/newbb/v ... id=406201#forumpost406201
Posted on: 2014/1/9 21:21
185 - 171kg = 14kg
factory F20C flywheel is 14lbs / 6.36 kg
factory ca18det flywheel is 29 lbs / 13kg
14Kg + 6.64 = 20.64kg / 45lbs extra
if ca18 used same fly weight as F20C
The height of the F20C engine is another issue
to fit a 1000 or other car they are massive donks
most of the clubman guys chop the bottom part of
the bellhousing and run dry sumping to fit
http://www.speedracersportscars.com.au/pictures/f20c1.jpg
Posted on: 2014/1/10 2:48
« 1 (2)
