What year is my truck?
From Las Vegas NV
So I have this truck on the title shows as 67 datsun the chassis code and vin start with b120 it has a A12 motor and a auto trans somebody else did the swap, on the grill I know uses the metal 3 piece grill like the one from the sedan 1200, how I can find what year is it, thank you all
jpg  image.jpg (73.88 KB)
12102_52d024888c8c1.jpg 600X448 px
jpg  image.jpg (41.52 KB)
12102_52d024ba90121.jpg 336X450 px
Posted on: 2014/1/10 16:50
Re: What year is my truck?
There should be identification under the hood on the firewall. The VIN number should be engraved on the firewall and usually starts with B120....
The year should be on the manufacturer's build plate also on the firewall
Posted on: 2014/1/10 21:34
From Las Vegas NV
I don't have the plate is missing but somebody told me the on the factory tail light will say the year also,
Posted on: 2014/1/10 22:03
From sydney australia
Its not a 1967 model, being a B120, which were built starting in 1970. With the steel grill, it's probably an early 70's model. Is the distributor at the front of the engine or next to number 3 cylinder? The front distributor A12 was made between 1971-1973, with 1973 onwards engines having the rearwards distributor. I'd try putting the VIN number in a search engine & see what entries you get. I always do that if I have a problem with other thngs, like how to multi-region a DVD player, or the last one was a Nissan part number for a H150 ring & pinion that I wanted to find the gear ratio for. This was for sale for about $50 on Ebay. I then found other sites in Russia where I could supposedly get a brand new 3.7:1 ring & pinion.
Posted on: 2014/1/10 23:15
Edited by b310gx on 2014/1/10 23:48:07
The first B120 came off the assembly line February 1971.
Posted on: 2014/1/10 23:46
Thanks Dave, Ive gone back & edited that out, so I don't look too ignorant. I notice it's a right hand drive, so surely there's some paperwork to do with the importation of this vehicle. Maybe the build year is on that paperwork.
Posted on: 2014/1/10 23:51
From Las Vegas NV
I don't have any of those documents I just have the California title
Posted on: 2014/1/11 23:47
No worries. Non-plastic grille and black interior were used 1971 to early 1978.
The are no appreciable differences in these years. Taillights should be the same all years.
Posted on: 2014/1/12 2:37
From Las Vegas NV
The distributor is on cylinder one
Posted on: 2014/1/13 2:50
