Offset Datsun 1200 Portugal
From Lisbon
Hi
I take the front measures chassis offset of my Datsun 1200 sedan 2 door sedan, and i have:
face measure 60mm
back measure 109mm
And you have:
face measure 109mm
back measure 89 mm
It is posible.
With measurements of my car i can use 13*6 wheels 175/60 tyres offset +23 mm
6"=152.40
centerline 152.40/2=76.20
76.2+23=99.20
76.20-23=53.20
face measure 60-53.20=6.80 clearance
back measure 109-76.20=32.80 clearance
I thinking wright?
Many thanks
Luis
Posted on: 2014/1/14 14:06
Re: Offset Datsun 1200 Portugal
That is a huge difference.
Can a third person measure a stock 1200???
i have: face measure 60mm back measure 109mm
And [the Offset tech article has]:
face measure 109mm back measure 89 mm
Be sure to measure with hub at standard height. Meaning if the car is jacked up and suspension drooping, the measurements will not be close.
Posted on: 2014/1/14 23:29
From Lisbon
Hi
You have reason, i took the measures when i have the car lifted.
The measures must be taken when i have the car lifted at the the same level at the other front whell?
To choose a correct offset that is the way a i had explain?
13*6 175/60 tyres withh +12 offset according with the standard measures i think they fit?
Many thanks.
Luis
Posted on: 2014/1/15 8:43
From Lisbon
Hi
With this measruments:
face measure 109mm
Back Measure 89mm
Whells 13*6
6"=152.40mm/2=76.20mm centerline
offset +12mm
offset +15mm
offset +23mm
Back measure 89mm Face Measure 109mm
76.20+12=88.20 76.20-12=64.20
76.20+18=94.20 76.20-18=58.20
76.20+23=99.20 76.20-23=53.20
According the chassis offset front whell the only offset i can put on My Datsun 1200 2 Door Sedan Year 1973 Europe (Portugal)is +12mm
Back measure
89mm-88.20mm=0.80mm clearance reducted
Face measure
109-64.20=44.80mm clearance
It is correct?
Many people says the use +12mm, +15mm and +23mm offset with any changes.
Many thanks on advance.
Luis
Posted on: 2014/1/15 14:10
Not correct. A 6" wheel is approximately 7" wide overall.
Posted on: 2014/1/15 20:14
