« 1 ... 50 51 52 (53) 54 55 56 ... 97 »
Re: Super Bee KA24DR Mod
From Trinidad and tobago
I really wondered,but this 1 seems much better made.Any idea what size of tubing an how long it has to be?Open in new window
Posted on: 2014/1/8 3:27
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Darrin, those are Lakewood "slapper" traction bars. They are very effective at controlling wheel hop in drag racing. Except as pointed ou t, they are installed incorrectly - too short. The last photo looks better. The spacing of the rubber bumper is adjustable for bite on drag starts.
They were basically cutting edge decades ago, so the design datsa73 is using is likely more effective.
Posted on: 2014/1/8 3:50
From Snohomish, WA USA
Dave,
Yep. That's my car and those are mine. I made those. 1x2 square tube. See how they extend to the forward leaf spring mounts. That's how they should be made. Take off your lower brackets and match the holes and make them. Easy.
Right now they are sitting on the floor in my garage.
Posted on: 2014/1/8 4:05
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
You made these slapper bars that have the Lakewood sticker? This photo was in Darrin's post.
Posted on: 2014/1/8 4:10
Oh I understand what your talking about.
Lake woods are not mine. You are correct. I built the ones in the prior post with the inset photo.
Posted on: 2014/1/8 4:14
'73 2 Door Sedan
From ATLANTA GEORGIA USA
Here is a picture of my SMS Assassin bars, they took the caltrack simple design and took it a lot of notches farther by giving them better adjustability and strength,
Posted on: 2014/1/8 4:30
SR20 Carbed Datsun B310
That's pretty cool!
Posted on: 2014/1/8 4:36
'73 2 Door Sedan
I expect the car to be back on the road by the end of the week. I managed to assemble the rear brakes, brake lines and E-brake while still getting some house work completed. I'm back to work for a couple of days. All that's left is to fill the diff with oil, reassemble my traction system and install the drive line.
Then I can get the car out of the garage and do a midwinter clean. The garage is mess.
Told myself at last seasons race when the axle broke that I would wait till spring to do the project. Early January and its pretty much done. When I start something, I don't like to mess around.
Will post some photos soon.
Posted on: 2014/1/14 4:15
'73 2 Door Sedan
Drove the car yesterday and as expected the 2.73 gears were dogs off the line. No wheel spin and very slow. No drama at all. I was able to make 50mph in first gear but didn't quite make the calculated 90mph in second gear!!
Here are some photos of the differential.
For the brake lines, I just used the Ford ones that were already on there. The splice between the left and right hubs is the same threads as the Datsun brakes so all I had to do is shorten the lines and use the Datsun splice. Hooking it up was a cinch.
For the E-Brake I swapped the left and right backing plates so the cables ran out the back. I was able to direct them around back up to the differential where I sandwich the outer cable sleeve between to steel plates with bolts to secure them. Zoom in the second photo. you can see it. The inner cables I just connected straight to the original E-Brake cable. That made that easy.
Next is to change out the 2.73 gears for some 4.10 or 4.30. Still need to decide what's best.
It was nice to drive it again.
jpg  IMG_20140115_151946_031.jpg (149.81 KB)
39_52d88938b7bec.jpg 816X459 px
jpg  IMG_20140115_151901_195.jpg (178.76 KB)
39_52d8894d4f37c.jpg 816X459 px
jpg  IMG_20140115_151838_101.jpg (149.01 KB)
39_52d889bd5cc7a.jpg 816X459 px
jpg  IMG_20140115_151811_296.jpg (141.07 KB)
39_52d889cf5f2f9.jpg 816X459 px
jpg  IMG_20140115_151758_415.jpg (142.05 KB)
39_52d889e4bebc0.jpg 816X459 px
Posted on: 2014/1/17 1:39
'73 2 Door Sedan
Nice work!
Posted on: 2014/1/17 8:13
