FS5W71B
Hi guys
I have an opportunity to get my hands on 5 5speed FS5W71B
Just wondering will they work on an a series engine. if not there is no point in me buying them....
Thanks
Posted on: 2014/1/27 23:04
Re: FS5W71B
Yes, it will fit if you use an adapter plate, some machining and fabrication.
The 71-series can handle 200 lb ft torque, so is a good choice for a high-boost engine.
Posted on: 2014/1/27 23:30
Re: FS5W71B
pm'd you
Posted on: 2014/1/28 0:21
Re: FS5W71B
Unless you need an extremely overkill gearbox, it is much better to find a good A-series transmission. See 5-speeds.
Posted on: 2014/1/28 10:33
Re: FS5W71B
Perhaps the most popular way to make an L-series gearbox fit an A-series engine is is to cut the front case and weld on a bit of case from a common A12 4-speed.
For example, Silva S15 6-Speed gearbox modified for use with A12 engine
See http://datsun1200.com/modules/mediawi ... ission_Swaps#Cut_.26_Shut
Posted on: 2014/1/29 1:55
