« 1 (2)
Re: A15 cam upgrade
i'm hoping the justy piston option will be cheaper than these !
http://www.ebay.com/itm/DATSUN-1200-H ... p=mtr&hash=item565e432b65
Posted on: 2014/1/30 14:02
Re: A15 cam upgrade
Custom forged pistons are only $400/set from Arias and other piston manufacturers.
Kamieiri is the most expensive brand in the world.
Posted on: 2014/1/30 20:58
Re: A15 cam upgrade
i'm thinking that for my application forged pistons are probably not required ?
Posted on: 2014/1/31 7:29
Re: A15 cam upgrade
No, but they are often less expensive
Posted on: 2014/1/31 7:32
Re: A15 cam upgrade
From sydney australia
Just had a look through Google & found this
http://www.google.com.au/url?sa=t&rct ... 1BZNZ3CptiGFtYh3IIRcqjC5A
Looks like pistons can be bought at $40 each. The ring set is expensive though, so maybe try sourcing those locally. There might even be somebody cheaper, like
http://www.google.com.au/url?sa=t&rct ... IfysIIfA_8mJeSJcLUCYDYpmw
Sorry, just had a look at that last one, lots of junk, but maybe some of the links can help. Why not try going to a Subaru dealer & see what they can supply.
Posted on: 2014/1/31 8:19
Re: A15 cam upgrade
yes, will go and see what they have tomorrow, and also motor factors to see if they have copy ones...
Time on my hands today and i found these:
Toyota 3ZZ engine (from a corrolla... all taxis here are corollas and parts for these are very cheap) worth having a look at also...
TOYOTA 3ZZ piston
part No 13101-0D070
qty 4
Piston dia 79
piston height 52.3
comp height 29.9+2.4-4.0
pin dia 20
pin length 50
Posted on: 2014/1/31 9:09
Edited by thaifrog on 2014/1/31 9:25:50
« 1 (2)
