Electric Choke Replaced
From Sri Lanka
Hi Guys
i had to replace my electric choke since i have lost its coil spring on my b310 , i had metal one i found a plastic one (black color) with single wire, fixed it it is working but carb door opens about 80% ,definitely it should be adjusted, to which side should i turn my choke housing to open the door fully when hot is it clockwise or anticlockwise ?
Metal one used to get very hot when working but plastic one doesn't get hot but works is it normal ?
thanks
regards
sumith
Posted on: 2014/1/11 4:13
Re: Electric Choke Replaced
Posted on: 2014/1/11 4:54
From Sri Lanka
Hi DD
I went through that article what i don't understand is that what is the door position of the carburetor at more choke and less choke situation , sorry for troubling
now my door position is similar to this position
http://s297.photobucket.com/user/ddgo ... _152143_DSC04286.jpg.html
so wanted to know whether to turn it clockwise or counterclockwise to make it open completely ?
thanks
regards
sumith
Posted on: 2014/1/11 5:19
Try it both ways - only one direction will close the choke butterfly flap. Hold the throttle slightly open while you turn the housing.
Posted on: 2014/1/11 5:59
From Sri Lanka
Hi Guys
Just Tuned the Housing clockwise now it is opening completely, How long should it take to open the butterfly complete ? mine now takes maximum 5 minutes to open it ,is it too fast ?that time engine temperature is bellow the operating temperature, what is the average time it should take ?
thanks
regards
sumith
Posted on: 2014/1/27 9:11
It should require about five minutes. Until the engine reaches operating temperature.
Posted on: 2014/1/27 15:18
From Sri Lanka
Hi Guys
Turning the Choke Housing Clockwise will open the Choke Butterfly More Quicker
thanks
regards
sumith
Posted on: 2014/2/3 23:27
You don't want it to open quicker. You want it to just barely close all the way when cold.
Posted on: 2014/2/4 0:11
From Sri Lanka
Hi DD
earlier it did not close completely so i turned the housing clockwise and it opens completely and closes when the engine is cold too perfectly
thanks
regards
sumith
Posted on: 2014/2/4 4:48
