What is the B310 Standard coil spring rate for the two rear springs?
Quite a regular
From Bendigo
Good afternoon everyone
Can someone please tell me what the B310 standard coil spring rate for the rear springs were.
Many thanks
Pete
Posted on: 2014/2/10 7:04
Re: What is the B310 Standard coil spring rate for the two rear springs?
Quite a regular
From Bendigo
Its OK, I found it... by getting the springs tested.
Posted on: 2014/2/11 13:35
So what is it? 96 lb/in?
Posted on: 2014/2/11 19:55
From Brisbane, Australia
could have found it by searching here too:
http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=61584
L18_B110 wrote:
Pitroad's B310 rear spring page says:
Pitroad spring 3.00k Free length 280mm
NISMO Spring 2.26k Free length 265mm
Normal spring 1.71k Free length 365mm
'Normal spring' means the standard spring. 1.71kg/mm = 95lb/in
Posted on: 2014/2/11 23:14
