(1) 2 3 4 »
igniton problems
my car recently wont run properly, im not sure why but it starts without the choke engaged
there is no ignition light and no oil light
when i put my foot down on the accel or drop it into 1st and release runs very sluggish and dies out
no spark?
im up for any advice at the moment im so stuck with my car.. and i need it for work
Posted on: 2014/2/14 8:12
Re: igniton problems
A clogged fuel filter can cause that. So can other things.
Posted on: 2014/2/14 18:56
From vic
Too rich? It would explain why it runs with no choke on
Posted on: 2014/2/14 22:32
im not sure if its running to rich float level is alright, it seems as its asif its not getting spark or something,
i have no ignition light and oil light when i turn the key before startup can anyone explain that?
Posted on: 2014/2/15 4:14
From melbourne
have you tried swapping out the Ballast resistor ?
Posted on: 2014/2/15 4:31
Key ON Engine OFF, the CHG and OIL lamps should light. If the do not the fuse may be bad.
Posted on: 2014/2/15 7:12
where is the ignition fuses? my fuse box isnt numbered with anything....
i tested my first spark lead while turning the starter over and the spark was very yellow and faint
im not sure where my ballast wire is because my wiring setup is all mixed up ..
Posted on: 2014/2/15 7:28
this is my wiring can you show me which fuses are for ignition and where the ballast resistor is?
https://fbcdn-sphotos-h-a.akamaihd.net ... 1802f67cd55fe25dda42581d3
https://fbcdn-sphotos-h-a.akamaihd.net ... 810edabec8b79b9699d4da7ce
Posted on: 2014/2/15 8:05
What Kind a Datsun is that? I'm no familiar with an 'ignition' light.
Posted on: 2014/2/15 8:26
its a datsun 1000 fastback coupe inported from japan
can anyone repost the links i posted and show me where the ignition fuses and ballast resistor is? :)
Posted on: 2014/2/15 8:39
(1) 2 3 4 »
