« 1 ... 38 39 40 (41) 42 43 44 ... 49 »
Re: Datsun 1200 Sedan Build
Does it drive much better with the correct timing now.
Looks nice but narrower front rims would be better to lower it like the front.
Thats the cleanest rear seat I have seen in a 1200 for years. Try get new base plates made for the strut bar. The mounting holes dont quite match up on yours so won't be as effective in stiffening front end if its poor fitting
Posted on: 2014/1/4 23:05
From Trinidad and tobago
It does drive alot better easier pull off,I will look at getting narrower tires to lower the front or might get 15's to put s13 brake.My back seat is very clean aye..
The mounting bracket will be made over soon doh.
Took her for a spin today.
Posted on: 2014/1/13 20:41
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Posted on: 2014/1/30 19:14
Street Sleeper!
From Snohomish, WA USA
Car looks good!!
Posted on: 2014/1/30 19:15
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Thank you.
jpg  Dattod.jpg (99.80 KB)
12526_52f1c6ae60335.jpg 482X642 px
jpg  Dattodf.jpg (99.22 KB)
12526_52f1c7db38d4a.jpg 482X642 px
jpg  Datto 4.jpg (141.04 KB)
12526_52f1c854d04bb.jpg 911X447 px
Posted on: 2014/2/5 5:12
Street Sleeper!
New Brakes upgrade coming up.
Have Fabricate the bracket out of metal now that the wood template works.
Posted on: 2014/2/17 3:05
Street Sleeper!
mmmmmmm
jpg  DAttooo 42.jpg (72.66 KB)
12526_531b5776b85e4.jpg 480X462 px
Posted on: 2014/3/8 17:48
Street Sleeper!
Posted on: 2014/4/5 0:24
Street Sleeper!
Brake setup is nissan B14 rotor an caliper on b310 struts clears 13'' wheels ventilated.The 1 that i will be using is gonna be cross drilled for extra cooling.
File centre so the disc could slide over the hub.
Centre hub and disc onto strut fits nicely
Had to file the caliper to get teh pads over to cut properly
Posted on: 2014/4/6 2:32
Street Sleeper!
Looks great darrenwilson
Posted on: 2014/4/6 2:35
