sunny brake upgrade
From penrith,sydney,aus
I've done some search through the wiki and the search bar with some mixed results
Just after a good brake upgrade for my 1980 sunny, it's running a sr20det, is there a good upgrade for the standard strut or would I be better off going to a different strut with an easier brake upgrade
Opinions
Posted on: 2014/2/9 22:33
2 door 1200 sedan project l20b stroker
Re: sunny brake upgrade
It is not common to upgrade, since B310 already has large 245mm disc brakes. The S13 250 mm discs might fit with custom bracket.
If your sunny was an A12 model, it might have the small 220 mm brakes, in which case swapping in A14 sunny struts is the way to go. Need struts, ball joint and knuckle arms.
Posted on: 2014/2/9 23:43
Yeah it was the a12 model, the disc is a reasonable size but the brake pads are stupidly small
Posted on: 2014/2/10 1:18
I've done abit more research and found a pic that pigdog put up saying a Vt caliper bolts directly to the sunny strut, also does anyone know if this works with the verada disc, and if so what model is needed
Posted on: 2014/2/10 10:23
Anyone???,
Posted on: 2014/2/20 7:28
From Sydney NSW
If yiu willing to spend the cash, why not a s13 silvia/180sx front end?? Wide range of front coil overs are tgen available
Posted on: 2014/2/20 12:29
There maybe faster ways to go...
But I'm never in a rush
Yeah thought about a s13 swap but I found a thread on here saying it was a fair bit of trouble
Posted on: 2014/2/22 9:49
S13 Brakes swap is a good one. But there are 4 different S13 brake systems so make sure you get the right parts.
Posted on: 2014/2/23 0:11
Thanks dd, the s13 swap with the hilux 4 pots looks pretty good , might go with that , thanks mate
Posted on: 2014/2/25 23:32
From Melbourne,Australia
A mate has bmw 4 pots (very similar to hilux) with verada discs on his sr20 sunny. Requires the use of 240k/200b struts but have a look here for more info
http://ozdat.com/forum/viewtopic.php?f=8&t=16542
Posted on: 2014/2/26 0:01
