« 1 ... 9 10 11 (12) 13 14 15 »
Re: Crumbs 2.4L coupe
Ah, so it an L20B that's been bored & stroked. Not an LZ hybrid (Z-series block with L-series head, or L-series block with Z-series head).
NAPS-Z is what some people call the Z-series engines, because some of the valve covers say "NAPS-Z". But technically NAPS-Z refers to the emission control system. There is also a NAPS-A.
Posted on: 2014/3/2 5:55
Does NAPS stand for northern american piece of sxxx lol
Posted on: 2014/3/2 6:23
NAPS is a Japan design. Used in Japan first then later in other countries.
Posted on: 2014/3/2 6:38
From Melbourne, Aus.
Posted on: 2014/3/2 6:59
Edited by crumb on 2015/1/22 12:17:47
Posted on: 2014/3/2 8:29
Edited by crumb on 2015/1/22 12:18:17
The engine definitely an L20B with a modified z24 crank and z24 pistons, giving it a 96mm stroke and 89mm bore. The head is a u67 which has been ported with oversized valves and the chambers been relieved. It's compression ratio is 10.5-1. Running a 74 high lift cam, advanced to bring on the power a bit sooner.
Posted on: 2014/3/2 11:02
Nice grunter
Posted on: 2014/3/2 11:08
From Melbourne,Australia
Nice job on the tune mate would be a heap on fun to drive now. Randys dyno does read low my car made 107rwkw on there a long time ago then at the ozdat dyno day made 128 on the same boost
Posted on: 2014/3/2 21:24
Posted on: 2014/3/3 5:40
Edited by crumb on 2015/1/22 12:19:12
Ha, I assume they're pulling you over to check your log book? I hear they're quite strict on those recently. I hope you had it all filled out correctly!
That area looks familiar, are you Eastern suburbs Melbourne?
Posted on: 2014/3/3 6:54
