« 1 ... 11 12 13 (14) 15 »
Re: Crumbs 2.4L coupe
From Melbourne AUS
sounds like your gearing is spot on (for 1/4 mile) if your at the very top of 4th over the line
good times, any street car that runs sub 15 is fun to drive
for comparison i did 13.7 @ 99mph in my old ute which had 150hp at the wheels
from memory my 60ft times were always around 1.8-1.9
i had 4.3 diff gears but around 8500rpm to play with
i wanted to give it another run with the 4.88 gears that i used to run on the track
just never got round to it
id like to drag my white sedan one day, should be good for a mid 13 id say
Posted on: 2014/3/9 12:25
1973 B110 A12
From Melbourne, Aus.
Posted on: 2014/3/10 11:01
Edited by crumb on 2015/1/22 12:13:44
So your at fault then tool :) sounds good you'll be happy if you beat the chaser
Posted on: 2014/3/10 11:23
Car free
From Melbourne AUS
what diff ratio is in it now? i think you'll need quite a large change in gearing if you want to complete the 400m
in 3rd gear? (thats how im reading it) I also think you'll go slower! 3rd-4th gear change can happen pretty quick with practice..
oh and if you need to work out diff ratio's you can divide the number of teeth on the pinion into the number of teeth on the
crown wheel, that'll give you your ratio
good to see you getting it out there and having fun, looks like you'll be in the 13's soon with some track time
then the quest to run a 12 second pass with an n/a 4cyl will begin! good luck
Posted on: 2014/3/10 11:54
1973 B110 A12
From Melbourne,Australia
Nice one that's some good times and mph Im keen to give the y another run one day best time ive done is a 13.6@105 when it was on gas really want to get into the 12's one day
Posted on: 2014/3/10 20:53
Good time for having never run the car before and without any experience. Must give those Commodores a good run for their money
Posted on: 2014/3/10 20:56
From Mordialloc Victoria 3195
Oooo that's motivation. Not surprised at the numbers Crumb, it goes good .
The motor's definitely coming out of the wagon and into the clubman this week. Then just get someone to sort out my Dellorto jetting without having to give up a kidney
Posted on: 2014/3/11 5:25
keep it simple
Posted on: 2014/3/11 8:14
Edited by crumb on 2015/1/22 12:14:41
Yes too many folk to serious. I guess once the numbers and mph on the board the bs stops.
Posted on: 2014/3/11 8:36
See that teach sh!t talk is why I wanted my coupe to look stock so I could go down and pull a quick time and them go wtf!! I think we should do a meet night there or at heathcote and bring some more dattos ie Pigdog, Ange, simon, rallycar ect and have some Datto fun
Posted on: 2014/3/11 8:41
Car free
