32/36 carby help
From Adelaide South Australia
Hey I just put on a 32/36 weber in my datsun 120y and the acelirator cable is to small im just wondering if anyone knows where I can get a bigger one that fits well or what one will fit well?
Cheers Hayden
Posted on: 2014/3/13 7:54
Re: 32/36 carby help
Do you mean too short? As in not long enough? Aftermarket cables are sometimes longer. How long is the cable you have.
Posted on: 2014/3/13 8:02
Im using the stock 120y cable with an old weber my friend had so I was Just wondering if there is another cable I could use that would be the correct size its only shorter about 30-50 mm
Cheers Hayden
Posted on: 2014/3/13 18:58
How long is the cable you have? Sounds like the wrong one.
Posted on: 2014/3/14 0:53
its the wrong one for the carby yes, its the stock datsun 120y im not sure as i havent measured it but its for a Right hand car and has a ball end
Posted on: 2014/3/14 5:17
From Townsville, Qld
I used the stock cable with a 32/36, just bolted the old linkage form the datto carb to the weber and hoped my plethora of zipties held it in the original clip on the rocker cover. For a while it did...
Posted on: 2014/3/14 8:39
My zipties lasted for years
Stock 120Y cable can be purchased at any auto.parts store cheap.
Posted on: 2014/3/14 11:22
