Re: egi intake
it doesnt squirt fuel but if i open the accelrator it just drips out of the jets i think
im going to try my old carburettor
whats a good replacement carburettor?
Posted on: 2014/3/25 7:22
Re: egi intake
One that works! If you bought a new replacement you ought to return it for one that works.
Otherwise buy an adapter plate and a weber 32/36 or a weber 28/36.
Posted on: 2014/3/25 7:43
Re: egi intake
it still wont work im really getting restless since i cant drive the car
i really dont want to be riding my bike to work anymore its been 1 month
its either i get it running or i go to efi
what would i need for EFI and are the custom manifolds pricey
Posted on: 2014/3/26 7:29
Re: egi intake
what would cause fuel going into my oil?
my compression in each cynlinder is around 100?
i just put in high octane fuel and electronic timing
carb level is in the middle and fuel comes out when i accelerate?
Posted on: 2014/3/30 5:42
Re: egi intake
Could be glazed bores from over fueling?, i did this in my early days playing with bike carbs on an A series comp went from 170 to 100 after a few sessions and fuel ended up in my oil.
Posted on: 2014/3/30 5:59
Re: egi intake
Or the fuel pump can be leaking into the sump.
Posted on: 2014/3/30 6:46
Re: egi intake
so my compression is low? how do i fix it? do i need to open my whole engine
im running a electric fuel mech pump is blocked off
Posted on: 2014/3/30 8:28
Re: egi intake
100 psi is a low reading, but that may be an uncalibrated gauge. Give it a wet compression test to check for sure.
Posted on: 2014/3/30 8:41
Re: egi intake
how do i do a wet compression test?
i used the compression tester from work which screws into the sparkplug hole
Posted on: 2014/3/30 8:59
Re: egi intake
Posted on: 2014/3/30 18:44
« 1 2 (3) 4 »
