(1) 2 3 »
FS: Caltrac Bars
From Brissy
I'm selling some custom made adjustable caltrac bars.
These bars will eliminate axle tramp and allow for a softer spring rate in the rear. Also keeps axles from rotating to help maintain pinion angle.
Made from 6mm plate steel with massive 16mm rose joints.
$220 pickup
$250 posted
Posted on: 2014/3/27 12:14
Edited by tappet on 2014/3/29 7:59:35
Re: FS: Caltrac Bars
Pics ?? Coupe sedan ute or any.
Posted on: 2014/3/27 12:29
From Brissy
Any 1200.
ill get some pics up this afternoon
Posted on: 2014/3/27 22:23
From Melbourne, Australia
i will grab them pending the pictures don't turn me off, pm sent
Posted on: 2014/3/27 23:25
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Brissy
Posted on: 2014/3/28 7:43
From Brissy
1) triangular brackets will need welding to the diff plates.
2) inner side of front eye mount will need to be drilled to 12mm
Posted on: 2014/3/28 7:53
yeah i'm keen on them, why does point 2) need to be done?
Posted on: 2014/3/28 10:53
1200 Coupe Rallycar
From Brissy
12mm bolt won't fit in a 10mm hole. :)
The front brackets go on the outer side of the front spring mounts.
so remove the stock bolt and redrill the inner side to 12mm (currently 10mm). tension it up to your liking as nylock will hold it in place.
Posted on: 2014/3/28 11:26
Quite a regular
Hey mate,
Are you still selling the caltrac setup?
Posted on: 2016/7/4 12:25
From Sydney
Advert is over 2 years old.....unlikely the bars are still for sale. Never know your luck though.
Posted on: 2016/7/4 12:31
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
(1) 2 3 »
