ca18 starter motor question
From Port Douglas. QLD
Hey guys,
went to kick the datto in the guts for the first time today. Fuel system primed ok, but the starter motor made this clanking racket and doesn't turn the motor.
Left scratching my head thinking maybe i have a fwd starter motor?
Anyone else had a similar experience?
Posted on: 2014/4/13 4:55
1200 ute
ca18det
Re: ca18 starter motor question
go it to kick over but not fire,
will resume testing later on.....after a beer and cyclone cleanup
Posted on: 2014/4/13 5:18
1200 ute
ca18det
Good to see that cyclone hasn't slowed down your progress.
I think Demacoz is using an EXA FWD starter on his and it's working fine. They are a little bit smaller and don't have threads in there locating holes so need a nut on the end of the two bolts that hold the starter to the block.
When I kicked mine over for the first few times all went well, but then the starter started making some concerning noises like it wasn't correctly engaging its gear with the flywheel. I luckily had a spare and put that in...which solved the issue.
Have a quick look on youtube and search on testing starter. With starter out of car there are several quick and easy tests you can perform with a screwdriver, battery cables and a battery.
Oh, make sure your battery has a good charge too, as the starter does put quite a load on it.
Great to hear the new power plant is coming to life!
Posted on: 2014/4/13 6:08
thanks,
Turns over fine, sparks but seems like there is no fuel.....testing further
Posted on: 2014/4/13 6:44
1200 ute
ca18det
omg,new motor in,same problem and i didnt have the brains to write down in my above post what i did to fix it.
grr
Posted on: 2014/6/25 10:58
1200 ute
ca18det
Posted on: 2014/6/25 11:09
Car free
Does it include swearing and hitting it? Works for me 10% of the time
Posted on: 2014/6/25 11:40
Bad earth. fixed and car fired up!
Posted on: 2014/6/26 12:02
1200 ute
ca18det
Congrats! Now whens the first drive?
Posted on: 2014/6/26 12:11
needs fabrication of piping. I cant weld and want something that is half decent. so off to fabricator next week.
Posted on: 2014/6/27 11:16
1200 ute
ca18det
