Factory A series engine paint code? Help.
Quite a regular
Hi everyone, I'm looking into painting my engine soon, due to it being a little bit filthy and the previous owner has painted the block and rocker cover a disgusting bright yellow.
I'd like to paint the block and rover cover in the correct stock A series blue.
Anyone know where to source this?
I realise you can get the paint code mixed up into a normal acrylic laquer, but can you get it in the heat proof engine paint?
I don't like the generic VHT bright blue.
Cheers
Posted on: 2014/4/13 7:56
Re: Factory A series engine paint code? Help.
Acrylic laqer is very old. Nissan would have used acrylic enamal.
Reportedly, engine block Datsun Turquois is:
Dupont mix guide mix size
806J HS BLACK 177.2
801J HS WHITE 290.0
828J HS FAST BLUE 373.8
830J HS FAST GREEN 444.4
702OG BINDER 844.0
7030G BALANCER 960.4
Posted on: 2014/4/13 8:19
From Goulburn NSW
Hi mate try www.restorerscatalogue.com.au they have specialised engine paints in assorted colours,they are in Sydney or google PPC(permanent paint coating)
Posted on: 2014/4/13 8:22
