Turbo timer
From Goulburn NSW
Hi guys is it necessary to have a turbo timer?
Posted on: 2014/5/21 10:51
Re: Turbo timer
From Perth WA AUS
Not if you drive like a granny :)
Posted on: 2014/5/21 10:55
Datsun 1200 2Dr sedan.
Re: Turbo timer
From Adelaide
Short answer, maybe if it's oil cooled. No if it's water cooled.
You only need a turbo timer if your turbo is oil cooled and you've been working it hard before you turn it off. The purpose of the turbo timer is to allow the oil to cool the hot turbo down before shut off. It is possible for oil to carburise (go hard) from heat soak if the turbo is hot from boosting and the oil flow stops. The water in a water cooled turbo soaks up this extra heat and would all have to boil off before damaging the oil so no worries.
Posted on: 2014/5/22 0:57
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
