Complete Guide Needed - W50 Toyota Box conversion
Not too shy to talk
Hi guys
I am looking for a full list of what i need do for a toyota w50 gearbox conversion and the rough cost- if anyone has all the stuff needed to convert as my friend has W50 box and autobox bellhousing - i am unsure of what needs doing.
Thanks
Posted on: 2014/5/22 22:15
Re: Complete Guide Needed - W50 Toyota Box conversion
From Sydney NSW
Are you talking buying a kit from Dellow or building one?
If from Dellow, about 2k will do everything bar the box, and cross member.
Posted on: 2014/5/23 0:35
There maybe faster ways to go...
But I'm never in a rush
From Townsville, Qld
Dellow don't offer an A series kit for the W range of gearboxes as far as I know because traditionally they were thrown behind v8 conversions.
Roughly speaking you would need to
- cut a slot in thebellhousing for the clutch fork
- weld on a ring to locate the clutch cable
- design a 1 inch adapter plate/ring to mate the box/ housing
- modify clutch fork setup to somehow attach to the adapter
- source the right size Toyota clutch plate (200mm) and machine flywheel to accept it
- machine a spigot bust to replace the datsun one
- have a tail shaft made/ modified
Posted on: 2014/5/23 2:20
From Sydney NSW
My bad I read 50, and immediately went to T series 5 speeds.
Posted on: 2014/5/23 2:46
