« 1 ... 7 8 9 (10) 11 12 13 ... 19 »
Re: VIC - drag day - June 15th 2014
I bought x2 20ltr gerrys today to make sure I got enough e85 for the day :)
Posted on: 2014/5/28 7:05
Car free
From Melbourne, Aus.
I have a couple of bit and pieces to do but nothing that would stop me from going.
Would like new shocks in the rear and add a leaf spring other than that there is always the small things.
Still looking forward to it.
Posted on: 2014/5/28 8:29
From Melbourne, Australia
you will regret putting an extra spring in, just get super stiff shockers
Posted on: 2014/5/29 7:00
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
I have to raise it off the bump stops, I have maybe 30mm of travel (after cutting them down by approx 25mm). The current spring aren't very good. Don't want to install a large spring but do need a little bit more height. Will be installing koni reds in the rear when i can get there, that should help.
Posted on: 2014/5/29 7:05
what have you done to it in the past? i was assuming your were adding an extra spring to stock leaf pack
Posted on: 2014/5/29 7:24
1200 Coupe Rallycar
It has been reset so the springs are flat or even sag the wrong way slightly, it has a custom spring in there that's almost as long as the top leaf yet there still soft. Somebody didnt know what they were doing when they reset them as they havent reversed the eye, there pretty crap. Thought i would get the shocks and add a small spring or just play around as i have a standard set and get them reset properly when i have a bit more money.
Posted on: 2014/5/29 7:32
His coupe has some custom leaves that are flat as a tack.
no travel and I think they were made to make it sit low but they handle like rubbish. 10mm travel to bottom out.
I said as a temp measure can swap leaves in a stock pack around to get it not as low but handle better. Not stiffer so it still squats to hook up.
Posted on: 2014/5/29 7:34
Try the shocks first, I'd be changing springs or getting them resprung before adding extra springs
Posted on: 2014/5/29 7:35
Car free
Put sedan leafs in
Posted on: 2014/5/29 7:36
Car free
Before i start pulling stuff apart does anyone know the cost of resetting spring? I'd much prefer to do it once and get it done right.
Posted on: 2014/5/29 7:41
