Any ideas to get a stuck steering hub off?
From socal, USA
I tried drilling to expose the teeth and useing a puller but the treads striped and the plastic behind keeps on shattering...
Posted on: 2014/6/11 22:35
Re: Any ideas to get a stuck steering hub off?
From socal, USA
Never mind being as impatient as I am I just torched it off heated for a bout 5 mins then pryed it off while it was still on fire then used about 2 gallons of water to put it out.
Posted on: 2014/6/11 23:03
From MOOROODUC. Victoria
well if at first you don't succeed, use a bigger hammer .... or a hot one
hope you didn't damage the spline or the rest of the car too much
Posted on: 2014/6/11 23:10
From SYDNEY,NSW
If not keeping it
Destroy it
Posted on: 2014/6/12 3:33
vouch points for PIGDOG J-Dat dats-me TRAV 40RST minitruckin 120fly DEMO 1200dat aidaniel matty discobob mick1200 cemax DATSKOOL - all have helped me out with parts...Thankyou
From Las Vegas NV
If that doesn't work let me know I have a locking column with gear box here in Las Vegas
Posted on: 2014/6/12 4:54
From Connecticut, USA
I've had luck cutting a grove almost all the way through the collar on similar stuff, using a dremel/cutoff wheel. Then sticking a huge screwdriver in the grove and spreading it open.
Posted on: 2014/6/12 4:57
