Clunk sound in front when braking in reverse.
From Connecticut, USA
I'm getting a clunk sound in front when I hit the brakes while in reverse(ex.backing out of a parking spot). I've had this issue 20 years ago on a same model(210) and can't remember what it was. I thought it was the idler arm but it seems good. Any thoughts? I would think others have had a similar problem. I check the caliper bolts as well. It is fine while breaking going forward.
Posted on: 2014/6/16 20:17
Re: Clunk sound in front when braking in reverse.
From Melbourne AUS
Check out your castor bushes, and obviously make sure
everything else is done up tight enough
Posted on: 2014/6/17 4:13
1973 B110 A12
From Wanneroo, Western Australia
It might just be your pads moving inside the caliper cradle. When you're moving forward, the pads are against the forward-most part of the cradle. When brakes are applied in reverse, the pads move in the direction of the rotor, making them to move about 1-3mm towards the opposite side of the cradle, thus causing a "clunk" when the pads make contact with the cradle.
Posted on: 2014/6/17 13:26
