Browsing this Thread:
2 Anonymous Users
Re: L16 twin su into a15 |
Smarise,
See if you can get someone to make a custom manifold to suit.Cheaper to get a steel one made as compared to cast alloy etc.Was quite surprised how well steel manifolds performed in rally events.
Posted on: 2014/6/14 2:23
thanks mate...
what is the negative side of steel intake manifold other that weight? if its suitable for daily use datsun, what will be the specification like the thickness of the flange and the manifold.
please help.!!!
Posted on: 2014/6/16 8:44
Measure thickness of your existing manifold flange
Posted on: 2014/6/16 9:16
thanks..
how about the thickness of the manifold pipe..?
mild steel or stainless steel?
Posted on: 2014/6/16 9:21
Use measurements of pipe diameter from l series manifold. You want to blend size in to inlet ports on head. Use which ever you think wont corrode internally or externally.
Posted on: 2014/6/16 9:35
hey mate, unless u leave in an area where its very very hot (desert) only then can sometimes the fuel vapourise enroute from the carbs as the steel retains more heat than cast alloy.
Steel manifolds were being used on road n rally in the coast where weather was 40-42 degrees with NO issues.and rally in africa isn't forgiving.
when making the manifold make sure ur flanges are thick on both the carbs end and also the engine to avoid warping/bending.also research if you want long or short runners manifold.
ive included an example of my brothers ke20 corolla intake manifold.could send more close up pics if you need mate.
cheers
Posted on: 2014/6/17 12:35
many many thanks bro....
the pictures really helpful... any difference between long and short runner...?
btw, pls find the picture of the steering box stopper. DIY. with stainless steel plate. just installed yesterday.
Posted on: 2014/6/17 13:47
Hey mate, just posted some quotes from around the web
"short runners on the intake manifold produce high end horsepower, where as long runners provide low end torque"
"Longer runners give you peak torque a lower/mid RPMs. Short runners are for high RPM race engines. For a street car the longer set up may be better for drivability."
please correct me if the info is wrong forum members.
hope that helps mate
Posted on: 2014/6/17 14:10
ignore the manifold, what is the different between the a14t su and L16 su. both 38mm bore?
Posted on: 2014/7/6 15:33
any idea???
Posted on: 2014/7/7 11:25
