Which spring/insert for Coilovers?
I'm back from overseas and I have plans for coilovers for the front.
So far I've sourced a set of complete 280zx struts and all the bits needed to make the 2" strut swap. I plan on using the Datsport coilover sleeve so I can run 65mm springs, use a dust boot and weld the sleeve on with the potential to run their camber tops in the future.
What I'm wondering is which spring rate and length should I be using and with which insert? I plan on running 95% street, 5% track and would lean to more of a firm ride. Currently I'm running an A12, with plans to move to an A14 in the future.
I'd also like to know if people have removed a section from the 280zx strut to shorten it before welding on the sleeve, I'd like to get the car as low as possible.
Cheers
Posted on: 2014/7/30 11:59
Re: Which spring/insert for Coilovers?
Bump, keen on getting stuff ordered asap
Posted on: 2014/7/31 1:15
8" long and 4~4.5 kg
N12 pulsar inserts and shorten struts to suit shocks
Posted on: 2014/7/31 7:36
Car free
With the help of the amazing superfatto, we've come up with this.
- VW Mk1 Golf Koni inserts
- 8" 200lb spring (still could use some feedback on this)
- Shorten the strut to suit the Golf insert
Any feedback on what people are using for spring rates would be appreciated.
Posted on: 2014/7/31 12:42
Edited by Flatto on 2014/7/31 13:09:30
Edited by Flatto on 2014/7/31 13:27:10
From Sydney
The spring choice is good for the street. Something around 220 - 250 if you want to do the occasional track day
Posted on: 2014/7/31 13:30
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Thanks Benny, Nick actually told me to go a bit firmer too but I thought it might be too stiff.
If that's what you both think then I'll go with the 220lb. I should have gone with fatto's advice in the first place :)
Posted on: 2014/7/31 21:40
What koni you end up with?
Posted on: 2014/8/2 4:12
Car free
8641-1048Sport
Posted on: 2014/8/2 9:42
