(1) 2 3 4 ... 11 »
DIY GILMER Drive A-Series
From Canberra
(ADMIN can we wiki this when i finish the DIY)
Ok i know a long time ago on here orange1200 set about doing the gilmer drive to his A14 but all of his said DIY got deleted by him so we actually do not have a DIY for a gilmer drive and i said F**** it i want one and ill make one myself and help other out whilst doing so.
So there is rumour that the chev small block long nose water pump gilmer drive is the go. Or others say other small block ones or even a 308 holden pully kit with modified pulleys,spaces,adaptors and belt to fit.
So i have gone out and brought a 350 chev small block with long nose water pump from Proflow. cost $170.00 delivered
The alternator pulley goes straight on, water pump pulley just needs the Center machined out a little and for the crank is the issue I'll either take one of my spare crank pullys get the v cut off the outside and machined with four bolt holes centered up and put together or I'll get an adapter plate cnc for it I'm aiming to have this done over the next few weeks so if it all works out I'll ensure to get the cnc code onto a USB and then we can get a few adapters made up for others whom would like to run a Gilmer drive
Here is what im going for video from youtube. http://www.youtube.com/watch?v=8nCoqVdnboQ (Admin please add video im attempting to add it as HTML request [flash=,]http://youtube.com/v/"8nCoqVdnboQ"[/flash] not working)
http://youtube.com/v/8nCoqVdnboQ
jpg  10484509_10152160223006148_401048089370173524_n.jpg (56.18 KB)
16063_53e95af245ac7.jpg 960X540 px
jpg  10320498_10152160222866148_3342649265957790104_n.jpg (60.72 KB)
16063_53e95b045c87c.jpg 540X960 px
jpg  10481678_10152160222951148_2086103708393875626_n.jpg (50.70 KB)
16063_53e95b128c10a.jpg 960X540 px
jpg  10603727_10152160222906148_5696005042001982889_n.jpg (39.52 KB)
16063_53e95b32ab029.jpg 960X540 px
Posted on: 2014/8/12 1:08
Edited by loosekid on 2014/8/12 2:04:13
Re: DIY GILMER Drive A-Series
Nice
I to have searched for this info.
Look forward to reading your info
Posted on: 2014/8/12 1:49
From Canberra
lucky for me i have a mate that has done this on a l20b engine this is what he has done. HE used a SBC kit.
Essentially the belt Lully was machined off in a lathe, a step put in it to help centre the new pulley and drilled and tapped, a local fan shop in Yass did it for me, cost less than $100 I think...
You'll also need to think about you're belt tensioner you need to keep tension on these belts to make them whine!
A 390 belt that i have will be too long I think... I may have to use a 345 belt..
jpg  10423979_10152625094588749_5157721655562946626_n.jpg (52.38 KB)
16063_53e965ae8c4e5.jpg 960X710 px
jpg  10404525_10152625094393749_3223528893529309619_n.jpg (52.19 KB)
16063_53e965bc0bb1a.jpg 960X710 px
jpg  10590651_10152625100833749_8128044160171571077_n.jpg (111.40 KB)
16063_53e965c6b18bb.jpg 960X710 px
jpg  10599636_10152625094753749_6236510623755261359_n.jpg (45.17 KB)
16063_53e965e9850fe.jpg 960X710 px
jpg  10592727_10152625102663749_7529836792121899432_n.jpg (131.30 KB)
16063_53e965f45ca8a.jpg 960X710 px
jpg  10613067_10152625100998749_2365018531789030711_n.jpg (72.52 KB)
16063_53e965fd6c49a.jpg 960X710 px
Posted on: 2014/8/12 1:55
From Melbourne AUS
Don't run too much tension on the belt. You'll destroy the bearings in your alternator and water pump real quick
Posted on: 2014/8/12 3:17
1973 B110 A12
From Canberra
So People with A-Series i just made it easy for you to obtain a gilmer drive kit with a 19mm belt the boys over at kemotorsport.com actually make a gilmer drive kit for $160.00 so instead of #OOPS#ing around with a SBC kit and then needing to machine just buy one of these and throw it on... Im buying a kit myself to test it out looks like good quality..
Wish i knew about this first :S
jpg  gilmer drive.jpg (67.68 KB)
16063_53ed50314b98b.jpg 640X480 px
Posted on: 2014/8/15 1:11
Edited by loosekid on 2014/8/15 7:43:43
Yeah, I've been trying to buy one off John for months but he doesn't reply to any emails.
Posted on: 2014/8/15 1:26
How did you buy yours?
Posted on: 2014/8/15 1:27
From Canberra
I Just emailed him clayons8 and he got back to me with in 20 minutes then i called him (0416080462) regarding it to to ensure.. sent through my shipping details to him and he replied with bank details.. Was quite easy try again if possible
Posted on: 2014/8/15 1:33
Thanks, Maverick(?).
I'll give him a call soon.
Posted on: 2014/8/15 1:42
From Canberra
Here you go boys this is what the gilmer drive looks like all done. (Admin can we get this info thrown into the wiki)
You can also run your original fan on the kemotorsport kit (not in picture)
jpg  10570376_10152178362001148_985950520013030085_n.jpg (110.50 KB)
16063_53f67b40bf4b7.jpg 960X960 px
Posted on: 2014/8/22 0:05
(1) 2 3 4 ... 11 »
