(1) 2 3 »
510 vs 910 front brake
Hi guys...
Hope gurus can advice me.
I have Datsun 510 front strut. Solid rotor.
I saw Nissan 910 front strut. Looks similar. Ventilated rotor, bigger caliper.
My question is, can just swap the 910 brake setup to 510 without any mod? I mean to swap the rotor, bearing hub, caliper...
Please advice....
Posted on: 2014/9/30 2:40
Re: 510 vs 910 front brake
From Malaysia
i did that on my 510. can't use the 910 springs because they are way too big. i use 510 springs but the spring are too small for the 910 strut. doesn't matter they fit but not snugly. the part in red circle is bigger on 910 than on 510. 510 spring can sit on that but not tight fit, if you know what im saying.
jpg  struttype.jpg (34.63 KB)
13172_542a529ba001d.jpg 350X280 px
Posted on: 2014/9/30 7:50
Thanks alot for the advice.
Btw, can I fit 13' alloy wheel to 910 strut?
Posted on: 2014/9/30 13:18
From Townsville, Qld
With the non import bluebird 13s can fit on the front, I imagine they would on the import brakes as they aren't much bigger
Posted on: 2014/9/30 23:43
From Malaysia
they do fit. I use 13" wheels on mine. No clearance issue.
Posted on: 2014/9/30 23:51
thanks...
bakat, the above attached picture is your car? the strut looks different...
Posted on: 2014/10/1 4:43
From Malaysia
no it is not. grabbed the picture from internet to show you which part im talking about.
Posted on: 2014/10/1 6:23
Hi. Im finding difficulties to fit 13" nissan 130y steel wheel. I believe alloy wheel should be no problem. Attached the strut which i bought. Need to fully refurbish.
Posted on: 2014/10/1 9:14
From Malaysia
my 510 with 13 inch jellybeans, 910 strut and brake
https://fbcdn-sphotos-e-a.akamaihd.net ... 302420dd38a61ecfee9652c34
Posted on: 2014/10/1 10:58
910 strut will give more negative camber than 510 strut, which is good!
910 imports used a variety of brake sizes:
* EUR: 238 mm
* JAP: 238 mm or 250 mm
* USA: 250 mm
The same rotors were used on C120 Vanette if you have trouble finding them.
Posted on: 2014/10/2 6:57
(1) 2 3 »
