Few Wiring Issues, Help Please
From Sri Lanka
Hi Guys
I have Re arranged all my wiring according to original color in the harness, so far everything looks good without few small issues,
(Please Refer Picture No 1)
I am looking for the Horn Trigger wire According to Manual It is (BG- black and green stripe)
but i don't have a slimier wire i have (GY) wire is it the Horn Trigger ? is it negative trigger ?
has The Yellow Arrowed Cooper plate to be touched with Steering Wheel Plate always ?
(Please refer Picture No 2)
When the parking or head light is on Right hand side brake illumination is very dark but left side works perfect ? what would be the reason (i am sahring only one Negative earth for all of them) But when i press the brake padel both are perfectly illuminating ? is it related to earth or bad bulb ?
shed your ideas guys ..
thanks
regards
sumith
jpg  1.jpg (123.02 KB)
10994_541f9c1885673.jpg 640X480 px
jpg  2.jpg (144.84 KB)
10994_541f9c2bc8520.jpg 640X480 px
Posted on: 2014/9/22 4:48
Re: Few Wiring Issues, Help Please
From Sri Lanka
Hi Guys
Any Ideas ? i am going to start the rest of the work tommorow
thanks
regards
sumith
Posted on: 2014/10/2 7:04
Re: Horn button wiring
Which is the Horn Trigger wire?
The wiring diagram on this site shows a Green/Yellow wire is the horn wire. It can differ by year and market.
See #43 direction indicator switch
and #41 horn relay
http://datsun1200.com/modules/myalbum/photo.php?lid=9757
It is a Negative switched wire. See Horn
Does the copper finger need to be touching the Steering Wheel Plate always? YES. Otherwise the horn will not work always.
Posted on: 2014/10/2 23:26
Re: Tail Lamps
* With Light Switch in PARK or HEADLAMP position, the tail lamp (not brake lamp) elements will light.
* With brake pedal depressed, the brake lamp elements will light.
So it is two different elements. Most likely the Bulb has one element burned out. But it could be that one of the two bulb pins is not making good contact. Remove and inspect.
http://www.ronfrancis.com/prodinfo.asp?number=B-1077
Posted on: 2014/10/2 23:42
Re: Tail Lamps
From Sri Lanka
Hi DD
Thanks i will look into those
regards
sumith
Posted on: 2014/10/3 2:09
Re: Tail Lamps
From Sri Lanka
Hi Guys
work Done successfully Horn Trigger wire has become pure green after the first
wire connector position , all done working fine connected Head Light too all good
Tuned the Engine I see nice drop of water drips from the tail pipe, so i am happy
with it,i have a nice plan of Led for the dash for that i have already bought few
Bulbs i am working on it now ,will update as work going on
thanks
regards
sumith
Posted on: 2014/10/4 0:08
