« 1 (2)
Re: 180B parts??
From sydney
on a side note, there are some 200B sedans with IRS in Aus.
Yeah true my 200B sedan was a rare one with IRS check it out in my photo album
Posted on: 2004/5/31 8:31
Re: 180B parts??
Drifft wrote:
(200b or 180b reguardless). if its a coupe it would be wrothwhile grabbing the twin SU's and manifold off it.
The twin carbs were discontinued in Australia during the 180B's [610] model run. The last of the 180B SSS model used the standard single carb engine.
The Australian 810 model used the L20B engine, hence the 200B model name, & the twins were only used on the L16 & L18 engine as far as i can tell. Even the 910 [Bluebird in Australia] had the twin carb option only on the L18 engine in those markets where it was available. Twin carbs seem to have never been offered on the L20B engine.
Posted on: 2004/5/31 12:16
Love your Datsun.
Treat it well.
Re: 180B parts??
From Sydney
my mates 200b coupe had twins su's, i thought they were just standard but maybe not? just going off the 180b sss's i have owned
Posted on: 2004/5/31 12:23
Street Tail Dancers
1200 coupe - A14
Re: 180B parts??
yes d/man i can really utilise this info.. why are u telling me this?? its totally irelevent to the post
woodydat
Posted on: 2004/5/31 12:37
78 model datsun 1200 ute. A15 twin webbers, dogleg 5speed.
Jk Rubicon unlimited, 58 CJ3B Willys
Re: 180B parts??
From Brisbane, Australia
you can use the 200B's L20 engine easier than the 180B's L18 as the sump configuration matches the 1200. The other L series engine with the right sump is the Stanza L16, not the 1600's (510). Only real difficulty with the L18 is the dipstick location. You can bolt on the correct oil pickup and sump from the 200B/Stanza, but you have to modify something to get the dipstick in the right place - eg drill block or put a tube into the side of the sump.
79 onwards 200Bs struts and brakes (244mm Girlock caliper - same as Stanza) are a good upgrade for a road car. But I can't remember what spring size they have...
Posted on: 2004/5/31 22:59
Re: 180B parts??
yeah thanks for the info... im gunna see my mate who knows the bloke to find out what year model etc it is an if its worth getting
Posted on: 2004/5/31 23:06
« 1 (2)
