A15 sump
From Sydney NSW
Is there a difference between an a12a a14, and an a15 oil sump?
Posted on: 2014/11/22 9:06
Re: A15 sump
Quite a regular
A15 is different to accommodate the crank rotation...has notches on the side
Posted on: 2014/11/22 20:09
Re: A15 sump
They are all the same don't listen to that nob
Posted on: 2014/11/23 4:44
Re: A15 sump
From Perth WA AUS
they are not the same,
same bolt pattern but an A15 needs more clearance for the internals.
Not sure about A14 though.
Posted on: 2014/11/23 11:53
Datsun 1200 2Dr sedan.
Re: A15 sump
From Sunshine Coast
Shut up flanders whalebone is right, ribs in sides for crank. A14 sump will hit with an a15 crank.
Posted on: 2014/11/23 20:41
Re: A15 sump
From Launceston, Tasmania
A15 sump is definitely different.
Posted on: 2014/11/23 23:27
Re: A15 sump
Quite a regular
Thanks for the support guys...from the NOB ?????????
Posted on: 2014/11/24 1:14
Re: A15 sump
From Perth
But you can use an A12 or 14 sump on a 15
I have
Mine didn't need any clearance... lucky I guess
Maybe my modified rods are the reason
Anyway... minor thumpy thumpy and your all good
Posted on: 2014/11/24 14:17
