QUICK BUT NOT LOUD...
Hi,
Have just put a weber 32/38 on my a15 1979 sunny. It's much quicker! My guy reckons I need extractors now and exhaust to suit. How necessary is this to the already MASSIVE improvement out of the weber?
I'm keen on making my Datto quick but NOT LOUD so was wondering
A: how much louder will extractors make the car?
B how much louder with extractors and appropriate exhaust make the car?
(PS what are other easy/cheapish mods can I make to see just how quick this little fella can go?!)
Cheers!
While I'm hea
Posted on: 2014/11/26 5:04
Re: QUICK BUT NOT LOUD...
You might not need headers, do you have a pic of number of your exhaust, cause the A14 and A15 versions usually have a nice cast iron header. Other mod is to get electronic ignition and if you need to do the head due to gasket failure in the future, skim a bit off to increase compression.
later a GX style cam grind, smaller diameter tyres/wheel combo and enjoy
Posted on: 2014/11/26 12:45
Elec ignition and a 2 inch press bend will be ok.
Headers make it louder . and tell might flow better but press bend will do. You won't get as much improvement as you did swapping to the carby
Posted on: 2014/11/26 21:10
