s13 brake question.....
From Port Douglas. QLD
Hey guys
Im a bit miffed after getting my hubs back from machining for my s13 conversion.....
- Had the car (85 ute) for a while and assumed i had stock disk brake struts
- Purchased coilover 1200 struts of supafatto (pm'ing you)
- Pulled everything apart and installed struts with camber tops and rca's
- Sent hubs for machining to fit the rotors...all good fits together well
- Go to install bearing but the ones that fit perfect on the stub axles do not fit the hubs :/ They are too big to be pressed in hub, but the ones that dont fit the stub axles fit the hubs and could be pressed in.
- So now im confused and wonder what struts i had on this car in the first place.
- I could machine the inside diameter of the of the hubs to fit the bearing? But if these hubs are potentially wrong......will they not work with the caliper adapter plates etc (kev rowley)
If anyone can shed some light on the issue that would be great
Cheers
Posted on: 2014/11/29 2:11
1200 ute
ca18det
Re: s13 brake question.....
Failing that,
Anyone got some hubs they can sell me?
Posted on: 2014/11/29 2:14
1200 ute
ca18det
Strut Part number 54302 H8800
Posted on: 2014/11/29 2:59
1200 ute
ca18det
Found out they are sunny struts/hubs
Posted on: 2014/11/29 3:14
1200 ute
ca18det
