Wtf h165 drum brake set up
Any one In melb have h165 drums shoes return springs and possibly tail Shaft flange or Shaft.
Need to complete the diff I picked up
Cheers
Posted on: 2014/12/6 1:36
Re: Wtf h165 drum brake set up
From Perth WA AUS
I'll be chasing the same parts soon :)
Posted on: 2014/12/6 7:31
Datsun 1200 2Dr sedan.
Uses the same brakes as 1200 sedan/coupe
The ones from the 1980s use the same brakes as B11.
Posted on: 2014/12/12 18:59
From Perth WA AUS
Cool, thanks DD.
Posted on: 2014/12/13 9:08
u can use H190 bluebird drum setup with 260z finned alloy drums too
Posted on: 2014/12/13 12:26
From Perth WA AUS
Thanks D, I might just bolt up the standard setup until I swap for discs.
Posted on: 2014/12/14 7:40
rear disks are overrated, I find drums better for streeter and track well Z rear drums in alloy and finned are legendary with great hand-brake turns for rallye & possibly drift as well
Posted on: 2014/12/15 1:13
Looks like the newer style brakes:
New 1200
Original 1200
New type has auto-adjusting mechanism
See Rear Brakes for a list of parts. B310 has the auto-adjusters.
Posted on: 2014/12/15 1:27
From Perth WA AUS
Ok, so I always disc rear end but drums are sounding pretty good now too.
About the 260z finned drums are they easy to get and any mods required D?
Here is what I have:
jpg  IMG_20141215_170404.jpg (145.71 KB)
9665_548ea64288631.jpg 778X584 px
Posted on: 2014/12/15 9:12
If you use the Bluebird drums from a H190 S3 then all you do is fit the alloy drums from the 240 or 260z as they use the same parts as the bluey.
This is what Steve Newing did for the H165 rear end on the 1000 coupe that he used to campaign and from what I heard its virtually a bolt on setup. The alloy drums are available from Z wreckers and gumtree.
Last time got quoted 30 a pair from Zworks in Brighton Melbourne but not hard to find.
Drums only provide a small % of overall breaking but when setup properly are awesome for hand brake turns or corrections for cornering, understeer and forced oversteer when power is not always there :)
Posted on: 2014/12/15 11:01
