Frustration!!!
OK, I am restoring a 1973 1200 coup to new. Have found almost every part I need as either NOS, salvage, or good quality reproduction except one. . .those Front wing/vent window seals! (You know, those triangle shaped windows on the front doors that pivot opened) I just need the seal/gaskets. . . I have found them for every other freekin model they ever made but not the coup. So, here is my question. Can you buy ones for another 1200 body style like the sedan or truck and modify them? Can you get them from another model car and modify? does anyone have any ideas or know if they are being reproduced or available?
Thanks,
Marc
Posted on: 2014/12/15 20:34
Re: Frustration!!!
From Geelong, Victoria
Try these guys http://www.scottsoldautorubber.com.au/Datsun%201970-74%201200.htm . I think what you are looking for is the last item listed under "Glass" section? I've never bought off them but have the website saved for when the time comes for me to replace rubbers.
Posted on: 2014/12/16 0:07
Re: Frustration!!!
Scott's has sedan/truck/wagon front Quarter window weatherstrips. Nissan has them too -- About 1/2 the cost of Scott's. Buy from new-datsun-parts or Nissan Japan Parts Business.
No one has Coupe version.
Great question. Sedan doors are a bit taller than coupe doors .... reportedly the seal is about 1/4 to 1/2 inch too long.
Posted on: 2014/12/16 0:37
Re: Frustration!!!
Thanks to both of you! OK, so maybe I can buy ones for the sedan and cut them down. Will give that a try and let you know what happens.
Thanks again!
Marc
Posted on: 2014/12/17 22:19
Re: Frustration!!!
From Sydney Australia
Sorry guys but someone does have coupe front quarter vent rubbers LH and RH, Try these guys.
http://www.spectrumrubber.com.au/imag ... trum_Rubber_Catalogue.pdf
Just double click on the png image attached to open in a new window so you can read it clearly
png  1200 coupe front quarter vent rubbers.PNG (150.59 KB)
13085_54b65b05bad0d.png 739X458 px
Posted on: 2015/1/14 12:03
Re: Frustration!!!
Good find!
221.101 Quarter window seals - front (coupe) LH
221.102 Quarter window seals - front (coupe) RH
http://www.spectrumrubber.com.au/vpg_new.html
Posted on: 2015/1/14 19:59
